TheCyberSeb Posted July 17, 2015 Report Share Posted July 17, 2015 Script récupéré sur le site de HP, ça remonte le nom du fabricant ainsi que le numéro de série du PC. strComputer = "." Set objWMIService = GetObject("winmgmts:" _ & "{impersonationLevel=impersonate}!\\" & strComputer & "\root\cimv2") Set colBIOS = objWMIService.ExecQuery _ ("Select * from Win32_BIOS") For each objBIOS in colBIOS Wscript.Echo "Manufacturer: " & objBIOS.Manufacturer Wscript.Echo "Serial Number: " & objBIOS.SerialNumber Next Link to comment Share on other sites More sharing options...
Pyrithe Posted July 18, 2015 Report Share Posted July 18, 2015 Salut! Merci de partager l'astuce! Mais perso j'utilise juste une ptite commande : wmic csproduct get vendor, name, identifyingnumber Exemple de sortie : IdentifyingNumber Name Vendor 2CE4070MYW HP ProBook 4740s Hewlett-Packard modjo 1 Link to comment Share on other sites More sharing options...
demonlight Posted July 18, 2015 Report Share Posted July 18, 2015 Merci pour l'info Link to comment Share on other sites More sharing options...
TheCyberSeb Posted July 18, 2015 Author Report Share Posted July 18, 2015 Salut! Merci de partager l'astuce! Mais perso j'utilise juste une ptite commande : wmic csproduct get vendor, name, identifyingnumber Exemple de sortie : IdentifyingNumber Name Vendor 2CE4070MYW HP ProBook 4740s Hewlett-Packard C'est encore plus simple Link to comment Share on other sites More sharing options...
Pyrithe Posted July 18, 2015 Report Share Posted July 18, 2015 C'est encore plus simple Link to comment Share on other sites More sharing options...
modjo Posted July 28, 2015 Report Share Posted July 28, 2015 Merci, c'est très utile. j'y avais même pas pensé, j’étais encore a galérer pour regarder sous le pc. +1 Link to comment Share on other sites More sharing options...
MathTek Posted July 28, 2015 Report Share Posted July 28, 2015 Script de récupération d'infos que j'avais fait rapidement en 2012 pour des PC Dell. On peut récupérer à distance, et ça donne: Modèle Nom Service Tag Version du bios Le script peut largement être amélioré car les infos donné sont en msgbox mais j'ai plus le temps et c'est plus mon domaine d'activitée. Script en VBS (donc à copier dans un fichier .vbs) strComputer = inputbox("Veuillez entrer le nom ou l'adresse IP du PC") if strComputer = "" Then Wscript.quit else Set objWMIService = GetObject("winmgmts:\\" & strComputer & "\root\cimv2") Set colItems = objWMIService.ExecQuery("Select * from Win32_BIOS",,48) Set colItems2 = objWMIService.ExecQuery("Select * from Win32_ComputerSystem",,48) For Each objItem in colItems2 MsgBox "Marque: " & objItem.Manufacturer & vbcrlf & _ "Modele: " & objItem.Model & vbcrlf & _ "Name: " & objItem.Name Next For Each objItem in colItems MsgBox "Service Tag: " & objItem.SerialNumber & vbcrlf & _ "Version du BIOS: " & objItem.SMBIOSBIOSVersion Next End if Wscript.quit Link to comment Share on other sites More sharing options...
TheCyberSeb Posted July 29, 2015 Author Report Share Posted July 29, 2015 Merci MathTeK Link to comment Share on other sites More sharing options...
xawey Posted July 31, 2015 Report Share Posted July 31, 2015 Salut! Merci de partager l'astuce! Mais perso j'utilise juste une ptite commande : wmic csproduct get vendor, name, identifyingnumber Exemple de sortie : IdentifyingNumber Name Vendor 2CE4070MYW HP ProBook 4740s Hewlett-Packard Nickel cette ligne de commande Link to comment Share on other sites More sharing options...
hgfyrglp Posted July 31, 2015 Report Share Posted July 31, 2015 J'avoue qu elle est bien !! Mais je ne maitrise pas encore wmic (je ne connaissais pas jusqu'à maintenant). Que faut il rajouter pour ajouter l'adresse IP de la machine et/ou son nom NETBIOS ? Merci Link to comment Share on other sites More sharing options...
modjo Posted July 31, 2015 Report Share Posted July 31, 2015 j'ai utilisé la ligne de commande mais les infos n’était pas suffisantes pour recupe les drivers. Link to comment Share on other sites More sharing options...
hgfyrglp Posted August 2, 2015 Report Share Posted August 2, 2015 J'avoue qu elle est bien !! Mais je ne maitrise pas encore wmic (je ne connaissais pas jusqu'à maintenant). Que faut il rajouter pour ajouter l'adresse IP de la machine et/ou son nom NETBIOS ? Merci Quelqu'un qui saurait ? Link to comment Share on other sites More sharing options...
fabrice Posted August 2, 2015 Report Share Posted August 2, 2015 Pour l'ip un truc du genre : wmic NICCONFIG WHERE IPEnabled=true GET IPAddress Pour le nom netbios, je ne sais pas si c'est accessible avec wmic Sinon, il y a systeminfo sous dos systeminfo | findstr /B /C:"Serveur d'ouverture de session" Link to comment Share on other sites More sharing options...
ALAIN95 Posted August 23, 2015 Report Share Posted August 23, 2015 Bonjour à tous BIOSVersion : version ; Manufacturer : fabricant ; Name : nom. Exemple : BIOSVersion={"ALASKA - 1072009","BIOS Date: 01/03/13 12:43:51 Ver: 18.06"} Manufacturer=American Megatrends Inc. Name=BIOS Date: 01/03/13 12:43:51 Ver: 18.06 La ligne de commande à exécuter avec le nom de la classe : wmic path Win32_BIOS get BIOSVersion,Manufacturer,Name /value Bonne journée Link to comment Share on other sites More sharing options...
Steph69 Posted January 2, 2018 Report Share Posted January 2, 2018 Pour les inventaires one shoot j'utilise Lansweeper en version démo (30 jours) éventuellement en envoyant un mail au service commercial pour avoir une clé extend (illimité 30 jours). Ça remonte toutes les infos du monde et ça permet de filtrer et d'exporter des rapports sous Excel. (en ligne, hors ligne, clientless, par GPO, over WAN, etc) Je désespère pas de motiver mon chef à prendre un abonnement entreprise pour gérer l'ensemble des parcs clients sous contrat en remplacement d'OCS qui est quand même plus limité (bien que gratuit !) Link to comment Share on other sites More sharing options...
